How to Reinstall EMI Shield after cleaning
iphone 5, I have reason to believe that the logic board has water damaged parts under the EMI shield.
how would I reinstall the shield after removing and cleaning?
Questa è una buona domanda?
Clean up or flatten out all the shield solder joints with a soldering iron and wick if you need it. Slip the shield back on and use an iron to solder the points again. You don't need to do a perfect job on every single joint. It helps if you try an avoid prying/bending the shield during removal.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 94
1 Commento
Read the answer below.
da icaremore
