Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Paper not leaving tray
Paper tray is full but printer indicates that it needs paper. It won't print.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
Kit per Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Risposte
First I recommend checking to make sure the firmware is up to date.
Next try a hard reboot I.e. Unplugging the power cable for 30 seconds.
Next if you are using another software to print try using the hp photo creation software, you might be getting an error for that reason
also make sure you select the right type of photo paper, there are a lot of choices and it makes a big difference .
also remove the regular paper from the bottom tray,only use the photo paper when printing photos. hope this helps you
Punteggio 0
Reset the product by following steps:
  • Turn on printer , disconnect the power cord from the rear of the product.
  • Unplug the power cord from the wall outlet.
  • Wait at least 15 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the rear of the product.
  • If the product does not turn on by itself, press the Power button
  • try printing again
  • if this doesn't work.....refer to Hp Photosmart 7520 Manual to contact HP technical support.
Punteggio 0
Aggiungi la tua risposta
Don sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 205
