Salta al contenuto principale
Rilasciato il 19 Settembre 2104, è la versione con schermo più grande (5.5") dell'iPhone 6.
1397 Domande Visualizza tutte
iFixit Replacement Battery Not Charging or Reading % right
Hi all,
I ordered the battery replacement kit for the iPhone 6 Plus and followed the replacement guide as closely as possible. I did run into trouble with the adhesive but eventually got the old battery out. When I put the new battery in, I found the connector didn't set very nicely, but I believe it connected, as well with the other connectors (the digitzer, etc) up top.
After reassembly I turned the phone on and was just happy to see it turn on successfully. After a few hours of use though I noticed the battery percentage wasn't reading right. It would keep flip flopping between numbers like, 12%, 9%, 12% again etc. I thought maybe a calibration would help, but when I let it charge overnight I noticed it didn't charge at all and stayed at 9% all night.
I'm really nervous and upset about this and hoping for some advice or help.
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
Kit riparazione batterie MacBook
A partire da $69.99
Buy Now
A partire da $69.99
Buy Now
3 Risposte
Soluzione Prescelta
If you bought a bad battery from iFixit. Just hit em up. They're pretty good at honoring they're warranty. I think I've had to do this twice in the past year or two. They respond and ship IMMEDIATELY
Punteggio 5
Sounds like a dudd battery, id contact the vendor for a replacement, even official apple batteries can be faulty.
Punteggio 4
Commenti:
Went to a repair place today and the battery was swapped out for one they had. Worked perfect after that. I bought the battery from on here. Bummer. Thanks for the reply.
da
As rayeasom says, absolutely replace the battery with another one, preferably one that is known-good, perhaps from another device.
If it fails, it is indicative of a charging problem on your logic board and requires a micro-soldering repair.
Punteggio 3
Aggiungi la tua risposta
Dalaney Vartenisian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 466
