Salta al contenuto principale
Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
56 Domande Visualizza tutte
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
Questa è una buona domanda?
Punteggio 3
10 Commenti
@shoeib hey bro, did you find a solution?
da
@ironjer - I'm sure a new fan fixed the cooling issue
da
@jesus no man. I eventually came to the conclusion that the logic board is fried.
da
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
da
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
da
Mostra altri 5 commenti
Aggiungi un commento
2 Risposte
Soluzione Prescelta
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
Punteggio 1
3 Commenti:
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
da
@danj would TG Pro read this?
da
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
da
See if any of the following articles can help:
Punteggio 1
Aggiungi la tua risposta
shoeib sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,726
