Salta al contenuto principale
The device to is in a bootloop and I can't system recover it .
So I got this estar tablet as a gift from a friend but I thought that the 512 mb ram was not enough for the 5.1 lollipop so I desided to root the device (with success) and use the ramexpander program which makes a part of the SD card into ram for the device to run a bit better. But after I installed the app and run it it didn't work so I thought maybe I had to just reboot the device ( btw the installation of the app was successful). When I rebooted the device it got into a bootloop, so I thought something got wrong so I should start it again and tried the system recovery. But in the system recovery if I press the navigation buttons the screen will change to the no command screen with the dead android picture. So I thought I messed up good times there. I then began looking for a new ROM for the device but I cant seem to find any for this device, but because of my inexperience on that theme I think I am doing something wrong. So I ask for help! Is there a possible way to fix my problem or did I bricked the device for good?
Specs: estar mercury HD quad core white mid 7358W
Ram: 512mb Android OS: 5.1 lollipop
Processor: quad core 1.3
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
When you get into the recovery mode and you see the no connection and the android laying on its back. Have you attempted to click the power button or at any other button on the device and see if that displays the menu?
I would attempt to do this first and see if it fixed your issue. Normally when you root a device you can back everything up. Everytime I root a device I download the stock ROM and the other ROM. Wherever you found the ROM, I would go back there to try and find the default ROM. I'm not sure if this is the ROM you need or not, it is displaying more model information that what you gave above, so maybe it will work, maybe not...check it out here
I am not sure if this has a removable battery, but if it does take the battery out for 2 minutes, and while the battery is out, hold down the power button for a minute. After the 2 minutes is up insert the battery. If it doesn't have a removable battery, just shut the phone down for 5 minutes. This will remove all of the left over electricity in the device.
If you can get into the Recovery menu, choose the option Wipe Cache Partition and then Reboot now once it is done. If that doesn't fix your problem, then you will have to get back into Recovery Mode and wipe to factory settings.
This is basically the only options you have until you find the stock ROM as far as I know. I am not sure if you can re-root the device, never tried it or heard about it.
Punteggio 0
Aggiungi la tua risposta
Alexandros Koutsogkilas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 941
