Hi,
As you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
Rice is good to eat but does nothing to fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit's guide on how to repair your phone. It is useful as it shows how to dis-assemble your phone so that it can be cleaned properly.
Samsung Galaxy S6
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
Votato
Annulla
Punteggio
4
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
7 Commenti
My galaxy s6 tablet has water damage should I put it in water?
da Jdnsjndh jdndnjndd
yes, submerge it in water.
da Rebecca Woldanski
Rebecca Woldanski - lol !
da Abigail George
My galaxy s6 tablet has water damage should I put it in bag of uncooked rice?
Hi @ndnfjdnjnjdj ,
Please read the answer in the Chosen solution above, especially the link on "Don't put your device in rice, here's why...."
I suggest that you follow the recommendations in the Chosen Solution answer above.
da jayeff
Mostra altri 2 commenti
