KERNEL PANIC - Boot "keep looping" - GPU Failure?
Hi everyone,
I recently changed my logic board with a new one (cause the old one was dead).
I've done a short try with my new logic board (30min) and everything was good. I didn't want to use my MacBook too long because I haven't yet change the Thermal paste.
Once I bought new thermal paste and apply on the CPU and Graphic card CPU, I booted my mac but It didn't start.
I had a boot failure and It was looping at startup (chime, loading 90%, reboot, looping).
So I did the following actions :
- NVRAM reset
- SMC Reset
- Remove and test RAM
- Boot on my rescue system and launch the Disk Utility -> everything is ok
- From Terminal and single user mode : execute all kind of fsck command -> everything is ok
- Then I reinstall my system from Time Machine -> Installation finished normally but no fix
- I've launched an AHT, no report except my battery (I've changed it a year ago)
- I finally succeeded to start in Safe Mode then I've been informed about a Kernel Panic, and it seems to be a GPU Failure.
Could you please give me some advise how to fix the problem and/or to confirm if it's a Graphic Card failure.
I will be very grateful
My Kernel Panic Report (First Part):
Anonymous UUID: D466DD1D-00B5-869E-7EA2-A159F6EF78DB
Sun Dec 25 00:41:30 2016
- Panic Report ***
panic(cpu 0 caller 0xffffff8009bce6fa): Kernel trap at 0xffffff7f8ba6837d, type 14=page fault, registers:
CR0: 0x000000008001003b, CR2: 0x0000000000000010, CR3: 0x00000002343b9000, CR4: 0x0000000000002660
RAX: 0x9bcbf090d3350001, RBX: 0xffffff80db144000, RCX: 0x0000000000000001, RDX: 0x00000000ffffffff
RSP: 0xffffff8113c3bae0, RBP: 0xffffff8113c3bae0, RSI: 0x0000000000000000, RDI: 0x0000000000000000
R8: 0x00000000ffffffff, R9: 0x0000000000000002, R10: 0x0000000000000000, R11: 0x0000000000000037
R12: 0x0000000000000000, R13: 0x000000000000073c, R14: 0xffffff80db144268, R15: 0xffffff80db144000
RFL: 0x0000000000010293, RIP: 0xffffff7f8ba6837d, CS: 0x0000000000000008, SS: 0x0000000000000010
Fault CR2: 0x0000000000000010, Error code: 0x0000000000000000, Fault CPU: 0x0, PL: 0
Backtrace (CPU 0), Frame : Return Address
0xffffff8113c3b770 : 0xffffff8009adab52
0xffffff8113c3b7f0 : 0xffffff8009bce6fa
0xffffff8113c3b9d0 : 0xffffff8009bec563
0xffffff8113c3b9f0 : 0xffffff7f8ba6837d
0xffffff8113c3bae0 : 0xffffff7f8ba52990
0xffffff8113c3bb40 : 0xffffff7f8ba528d4
0xffffff8113c3bb60 : 0xffffff7f8ba2e67a
0xffffff8113c3bba0 : 0xffffff7f8a91b0b5
0xffffff8113c3bbf0 : 0xffffff7f8a91afc8
0xffffff8113c3bc10 : 0xffffff7f8a91f532
0xffffff8113c3bca0 : 0xffffff7f8a91710b
0xffffff8113c3bcd0 : 0xffffff7f8a967ae8
0xffffff8113c3bd20 : 0xffffff800a094fb1
0xffffff8113c3bd70 : 0xffffff800a0df0b9
0xffffff8113c3bde0 : 0xffffff8009b97a71
0xffffff8113c3be30 : 0xffffff8009adf2c3
0xffffff8113c3be60 : 0xffffff8009ac28f8
0xffffff8113c3bea0 : 0xffffff8009ad26a5
0xffffff8113c3bf10 : 0xffffff8009bb8eca
0xffffff8113c3bfb0 : 0xffffff8009becd86
Kernel Extensions in backtrace:
com.apple.iokit.IOGraphicsFamily(2.4.1)[A360453D-2050-3C49-A549-AC0DD5E87917]@0xffffff7f8a90d000->0xffffff7f8a947fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[5447B943-A94D-3BD4-A60F-98B24D19CE93]@0xffffff7f8a32c000
com.apple.nvidia.classic.NVDAResmanTesla(10.0)[05FC5D7E-BB0B-3232-BBBD-8A49B6870D8B]@0xffffff7f8a964000->0xffffff7f8abd9fff
dependency: com.apple.iokit.IONDRVSupport(2.4.1)[4EB2843C-C821-3AD0-B333-575FD6ED6FB1]@0xffffff7f8a954000
dependency: com.apple.iokit.IOGraphicsFamily(2.4.1)[A360453D-2050-3C49-A549-AC0DD5E87917]@0xffffff7f8a90d000
com.apple.GeForceTesla(10.0)[07CD2F70-A8DD-32EA-85C0-90433204BDAC]@0xffffff7f8ba2b000->0xffffff7f8baf6fff
dependency: com.apple.nvidia.classic.NVDAResmanTesla(10.0.0)[05FC5D7E-BB0B-3232-BBBD-8A49B6870D8B]@0xffffff7f8a964000
BSD process name corresponding to current thread: WindowServer
Mac OS version:
15G1004
Kernel version:
Darwin Kernel Version 15.6.0: Mon Aug 29 20:21:34 PDT 2016; root:xnu-3248.60.11~1/RELEASE_X86_64
Kernel UUID: E349749B-3303-3DDF-959C-B5885A0E1F6E
Kernel slide: 0x0000000009800000
Kernel text base: 0xffffff8009a00000
__HIB text base: 0xffffff8009900000
System model name: MacBookPro5,2 (Mac-F2268EC8)
KERNEL PANIC WINDOW SERVER Details (First Part) :
Process: WindowServer [167]
Path: /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/WindowServer
Identifier: WindowServer
Version: 1
Code Type: X86-64 (Native)
Parent Process: launchd [1]
Responsible: WindowServer [167]
User ID: 88
Date/Time: 2016-12-25 01:03:10.349 +0800
OS Version: Mac OS X 10.11.6 (15G1004)
Report Version: 11
Time Awake Since Boot: 240 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
Assertion failed: (x_list_nth(active_managed_displays, 0) == PKGDisplayGetSpaceData(pkg_display)), function __session_data_handle_display_config_change_block_invoke395, file Server/Packages/PKGSpace.c, line 7409.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x000000010a432f06 __pthread_kill + 10
1 libsystem_pthread.dylib 0x000000010a5aa4ec pthread_kill + 90
2 libsystem_c.dylib 0x000000010a32c6df abort + 129
3 libsystem_c.dylib 0x000000010a2f3dd8 __assert_rtn + 321
4 com.apple.CoreGraphics 0x000000010726d3de __session_data_handle_display_config_change_block_invoke395 + 121
5 com.apple.CoreGraphics 0x000000010726ce96 __PKGSessionSpaceDataInit_block_invoke + 631
6 com.apple.CoreGraphics 0x00000001072d3e37 (anonymous namespace)::PKGDisplay_display_config_changed(CGSNotificationType, void*, unsigned int, void*) + 2967
7 com.apple.CoreGraphics 0x00000001073eb1bd (anonymous namespace)::ServerNotifier::invoke_callbacks(unsigned int, void*, unsigned long) const + 313
8 com.apple.CoreGraphics 0x00000001073e9ec6 WSPostLocalNotification + 104
9 com.apple.CoreGraphics 0x00000001072bed96 CGXSelectDisplaySet + 905
10 com.apple.CoreGraphics 0x00000001071c30e4 __CGSessionMovedOnConsole_block_invoke + 47
11 com.apple.CoreGraphics 0x00000001071bf7c8 session_dispatch_sync + 53
12 com.apple.CoreGraphics 0x00000001071c159e CGSessionTakeConsole + 849
13 com.apple.CoreGraphics 0x00000001071c251e yieldConsoleCallback + 565
14 com.apple.CoreGraphics 0x0000000107244ad6 run_timer_pass + 547
15 com.apple.CoreGraphics 0x00000001072c4355 CGXRunOneServicesPass + 140
16 com.apple.CoreGraphics 0x00000001072c67b1 CGXServer + 7273
17 WindowServer 0x0000000107032f7e 0x107032000 + 3966
18 libdyld.dylib 0x000000010a2525ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x000000010a433efa kevent_qos + 10
1 libdispatch.dylib 0x000000010a1ff165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x000000010a1fedcd _dispatch_mgr_thread + 52
Thread 2:: com.apple.CoreAnimation.render-server
0 libsystem_kernel.dylib 0x000000010a42cf72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x000000010a42c3b3 mach_msg + 55
2 com.apple.QuartzCore 0x000000012aaa78df CA::Render::Server::server_thread(void*) + 257
3 com.apple.QuartzCore 0x000000012aaa77d7 thread_fun + 25
4 libsystem_pthread.dylib 0x000000010a5a799d _pthread_body + 131
5 libsystem_pthread.dylib 0x000000010a5a791a _pthread_start + 168
6 libsystem_pthread.dylib 0x000000010a5a5351 thread_start + 13
Thread 3:
0 libsystem_kernel.dylib 0x000000010a4335e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x000000010a5a7578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x000000010a5a5341 start_wqthread + 13
Thread 4:
Thread 5:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff58bbcc48 rdx: 0x0000000000000000
rdi: 0x0000000000000c0f rsi: 0x0000000000000006 rbp: 0x00007fff58bbcc70 rsp: 0x00007fff58bbcc48
r8: 0x0000000000000000 r9: 0x0000000000001cf1 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x0000000108257623 r13: 0x000000010a150000 r14: 0x000000010a5b0000 r15: 0x000000010825732c
rip: 0x000000010a432f06 rfl: 0x0000000000000206 cr2: 0x0000000108335000
Logical CPU: 0
Error Code: 0x02000170
Trap Number: 133
Questa è una buona domanda?
Hi, Thank you for this suggestion, but it didn't changed anything to my problem.
I'm 99% sure it's a graphic card problem. If someone else has an idea :)
Thanks
da Thomas Cayrol
