Salta al contenuto principale
The Canon EOS 60D is a 18 MP DSLR (digital single-lens reflex) camera with an articulating LCD screen. The camera was released August 2010 and is identified by the EOS 60D printed on the front of the camera.
56 Domande Visualizza tutte
Canon 60D won't turn on?
I have a canon 60d that is about a year old. About 2 months ago it just completely "died", used it one day, put it back in my camera bag, went to use it the next day and it appeared dead, even though I just placed a fully charged battery in there. Tried different batteries, battery pack with double A batteries, nothing. It doesn't flash any lights, doesn't make any noise or shown any signs of life when switched on.
Any idea on what it could be?
I'd hate to spend $400 or whatever it may be, to be sent ti canon to repair it when the body itself is really worth less than that. I'm just feeling as if I might as well invest that $400 into a new body.
And yes I have tried the switches on both the battery compartment and memory card compartment, nothing at all.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Risposta Più Utile
Hi, I just had this happen to me.
I'd just started using a new lens (50mm 1.8 STM) and tried different combinations of lenses, etc.
Both batteries I tested were full or near full.
Long story short: it turned out to be caused by the micro-SD card in a Transcend SD adapter! Once I'd taken that out and removed / replaced the battery, everything worked as before.
Really, really weird.
Punteggio 2
2 Commenti:
Thanks, I took my sd adapter out and flipped the power a few times without and with thr battery in and it works now.
da
Thanks.. This worked a treat! Pulled out battery..popped in other SD card.. and back in business! Thank you!
da
Saludos. Soy de Venezuela . Tengo un 60D y la tengo guardada desde hace unos meses, la estaba usando y dejo de funcionar. En la pantalla superior el simbolo de bateria empezo a prender y apagar, luego dejó de hacerlo y no funcionó más aunque las baterías estén cargadas.
Punteggio 0
Format your SD card. I had that problem a year ago, turns out that the SD card was the issue idk why.
Punteggio 0
Aggiungi la tua risposta
Isabella Lumley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,847
