Sarah Rouse , Found this info from anthony82 at HP forum, also posted a link for you to check out on same issue you are having and how to get device touch pad two finger scroll and pinch to zoom function working.
It could be a problem with the synaptic software.
Go into control panel and uninstall the synaptic program.
Start -> Type Control Panel -> Uninstall program -> right click and uninstall synaptic.
If it has you restart, go ahead.
Now pull up recovery manager
Go to start -> type Recovery
You should see recovery manager in the list
Open recovery manager and click software and driver re installation
Go through the list and find synaptic and reinstall.
It says synaptic driver but the program is with the driver
Good luck.
http://compixels.com/3115/enable-multi-t...
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
