Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1623 Domande Visualizza tutte
Battery not charging after changing thermal paste
Hi there!
I have changed the thermal paste and upgraded the RAM of my two MacBook Pro "13 Mid 2012. Everything seems to go OK, except for one of them. After mounting everything in the right place, the computer boots normally, but the battery does not charge. The led in the charger doesn't light. I have checked the battery connection and seems OK, even if I unplug the charger the computer continues running with it charge.
I have also reseted the SMC.
Might I have messed something from the DC IN?
Thank you in advance.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I realised that I had slightly cut a cable from the jack power board when mounting back the logic board. So, I need to replace this component or maybe do some soldering work.
Punteggio 0
Risposta Più Utile
No, the DC in board is working perfectly if the computer is turning on. When you say the battery does not charge, do you mean that there is no light on the charger? Does it only stay green? Does OS X show a percentage of the battery?
Punteggio 1
2 Commenti:
Thank you! The charger light was very weak. OS X showed a percentage of the battery that didn't decrease nor increase. It displayed a "battery not charging" message under the battery menu. I guess that the MacBook wasn't getting power supply enough.
da
did you find the solution of it i am facing the same problem @Enrique Cerrillo Cuenca
da
Aggiungi la tua risposta
Enrique Cerrillo Cuenca sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 675
