Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone turns on but you the screen is completely dead?
My Iphone had liquid damage but when I charge it the phone turns on because you can hear my notifications coming in. The screen doesn't come on though? Is this repairable?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Chances are the water damaged your FPC connectors or the LCD/Backlight circuit.
Do the following as soon as possible:
  1. Open your phone and remove the logic board (follow this guide)
  2. Inspect the logic board, especially around the connectors and look for corrosion.
  3. Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  4. Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  5. Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  6. Rinse in alcohol and repeat.
  7. Let it air dry for a day.
  8. Re-assemble and hope for the best.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
Punteggio 1
Risposta Più Utile
Yes, follow this guide and replace the battery with it.
Electronics Water Damage
Also, can you see the screen if you shine a bright light on it? (Sunny day, flashlight, etc.)
Punteggio 1
3 Commenti:
I cant see anything at all but i can hear it
da
even when i shine a light on it
da
I recommend you get the phone opened. The sooner the better. Just leaving it closed is letting any liquid still wet or set in there to cause more damage to the point where it may not be repairable.
da
Aggiungi la tua risposta
cammy todd sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
