Xbox one S sizzling power noise
Hi Guys,
I have just bought a new Xbox one s and I realized, that when the machine is turned off, it has a sizzling noise probably from the internal adapter. I have tried with different cable and different sockets and still the same. I took it back to the shop where I bought it and we could not hear anything as the shop is noisy and the noise from the xbox is quite low, but am still worried there will be some problem with it. The guy told me I have to try to connect the xbox to an extension cable, rather than to socket. I just got home and tried, but still the same noise. Does anyone know what the problem is or any solution for that?
Thanks for the answers
Questa è una buona domanda?
2 Commenti
My Xbox one s after a storm cam by it won’t turn on after that I took it to a repair shop and they said it reúnes on fine and they fixed the HDMI port but as I take it home it turns on makes a noise then turns off, also when I plug in the power cord the thing the goes into the back of the Xbox is making a weird noise it either sounds like electricity or something else I don’t know, but I need an answer or I’ll just by a new one
da Emmanuel Garibo
The noise is normal, but if you want to get rid of it try changing your xbox power setting from energy saver to standby mode.
da Moocow93
