Salta al contenuto principale
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Domande Visualizza tutte
Can I use a nail file?
Can I use a nail file to clean the corrosion in the game card slot or do I have to use a Q-Tip with rubbing alcohol on it?
Questa è una buona domanda?
Punteggio 0
3 Commenti
What exactly are you cleaning?
da
The game card slot.
da
Never use a nail file, you'll damage the components even more.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Don't use a nail file to clean corrosion, you will damage the components on the board.
Use a Q-tip or toothbrush and 95%+ isopropyl (rubbing alcohol)
Punteggio 4
4 Commenti:
I have 70% isopropyl, is that ok? Also, I am cleaning the slot where you put the games in.
da
It's also 30% water so make sure it's dried out before testing.
da
ok, how do i dry it out?
da
You leave it to evaporate. Personally I use 99% isopropyl to bath liquid damaged boards after an ultrasonic clean. This helps quicken the drying process since it evaporates quicker than my ultrasonic cleaning solution. Usually check them a day after this to completely dry
da
Aggiungi la tua risposta
kdcao1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 79
