Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
How do I trigger the Home button without the front assembly?
I have an iPhone 3GS that was dropped, The entire front panel assembly (glass, LCD, home button) is broken.
I want to see if I can restart it, but for that to happen, I need to somehow close the Home button circuit to emulate the button.
I've tried connecting the two fields that would have hit the button prongs, but I'm not having any luck.
Questa è una buona domanda?
Punteggio -1
1 Commento
what is it you want to do with phone when it's on?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You guessed right. To emulate the home button being pressed you need to short the two exposed pads. I like using a pair of metal tweezers, but you can use a paper clip bent into a "U" shape.
EDIT: Click the image for a larger resolution. Sorry about the rotation.
Punteggio 1
Aggiungi la tua risposta
Christopher M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,325
