mini A1283 with 256 GB Sandisk X400 SSD
mac mini late 2009 model A1283
I'm upgrading this mac mini with 8 GB RAM and the 256 GB Sandisk X400 SSD. Computer runs fine and boots normally off of original hard drive which has Yosemite installed with 8 GB RAM installed.
I've been trying to get the SSD working and it now has El Capitan with latest updates. I've not been able to get this SSD drive working in the internal slot. System boots normally off the old drive in the internal slot, the system boots El Capitan from the Sandisk SSD if it is put in an external inatek enclosure. System will boot normally with the SSD in the external enclosure, with no drive in the internal slot. So long as the SSD is connected from the external enclosure, everything is fine, system runs El Capitan, and shows 8 GB RAM installed.
If I put the SSD into the internal slot, I get a grey screen. No question mark, no nothing. The only boot key sequence it seems to recognize is reset NVRAM, which I have tried multiple times. No other boot key sequences are recognized. Can't bring up boot manager, can't boot off DVD, nothing. I tried downloading an old EFI firmware update recommended elsewhere. Booted into El Capitan, it says this update is not needed.
I could just run this off the external enclosure, but would prefer to get the SSD working normally in the internal slot.
Any ideas?
Questa è una buona domanda?
4 Commenti
Did you format the drive GUID and Mac OS X extended first?
da mayer
Yes, using Disk Utility from the "Install OS X El Capitan" installer. It currently shows "OS X Extended", partition map: GUID Partition Map, under Disk Utility booted into El Capitan.
da eric Ogata
Your systems specs: Mac mini 2.66 GHz Core 2 Duo (Late 2009)
Your SSD's specs: SanDisk X400 SSD
da Dan
I've looked at those Dan, but perhaps I missed the fact that SATA III (this Sandisk X400) is 6 Gb/s and the mini is SATA 3 Gb/s (i.e. SATA II). The Sandisk specs do say the X400 is backward compatible to SATA II and SATA I, and this was the recommended SSD for this system. But perhaps that is the problem?
da eric Ogata
