I can't listen to music
I am trying to listen to music, but I can't hear anything even though, I raised the volume to maximum.
Questa è una buona domanda?
First of all you need to know if the problem it's only with the speakers or is a software issue.
Try to go to settings and look for the volume settings to be sure everything is on the top level.
- If that is checked and it's still not working then try to use a headphones to check if works that way.
-I am assuming you already tried to reset the tablet then if nothing works, the problem for sure will be hardware, now you need to open the tablet and look for a lose connection with the speakers inside.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 63
