Powers itself off after about 5 minutes.
PowerMac G5 DUal 2.0 Ghz PCI-X
Serial No. : CK411J3JQVJ
This PowerMac works perfectly... until it powers itself off.
I expect it needs a new PSU? but which one ?
Questa è una buona domanda?
Energy Saver computer sleep & put hard drive to sleep settings.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Try this first +
To me it sounds like overheating of either the power supply, or the CPU. I'm sorry but I can't help you with the power supply diagnosis CPU overheating could be from myriad problems, sensors, logic board, fans, old dry thermal paste.
Thanks,
There are no Kernal Panics or such Screen output.
Nothing is logged in the system.log in Console.
The Energy / ScreenSaver settings are OK.
The power cuts out, just like the plug had been pulled, it is not a usual shutdown or timed logout sequence.
Please post this as a Update to your Question or a comment to my Answer only Answers belong here.
awaiting new PSU... will report back on result...
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 917
1 Commento
Seeing a kernel panic notice on screen?
da originalmachead
