Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1696 Domande Visualizza tutte
PS4 CUH-1215a optical drive replaced, still won't accept discs, help!
I was playing playing GTA Online happily one night, turned system off via controller menu after closing all applications, went to bed. Went to work the next day, got home, turned system on, tried starting GTA, and got a disc read error. Powered off the system, waited a few minutes, and powered back on. This time I got a message that the disc wasn't inserted, even though it was. I assumed the optical drive crapped out on me, since it wouldn't eject or read the discs... In fact, the optical drive was making no noise at all. So I ordered a new optical drive from eBay. While I was waiting for it to arrive, I tried all the fixes I could find... Booting into safe mode and rebuilding the database, reinstalling the system firmware, to no avail... I haven't tried restoring to factory settings yet, as my wifi is painfully slow, and I don't want to have to wait weeks for the rest of my digital collection to re-download.
Got the new optical drive in, and replaced it using ifixit's handy guide. :) I made sure all the cables were firmly connected, reassembled, plugged in, and prayed... new drive made no noise, and wouldn't feed the disc in. Crap. $100 wasted. I tore EVERYTHING apart this time, and looked over the motherboard, all the ribbon cables, etc... The ribbon cables all LOOK fine to me, no folds or damage other than the usual "guiding" folds. Checked out the motherboard, I see no missing or loose pieces, no scorch marks as if something overheated, nothing... Granted , I don't know EXACTLY what I'm looking at, but everything looked okay to me... I'm at my wit's end... I don't know why 2 optical drives are dead in the water... Do I need to just suck it up and order a new motherboard, or is there ANYTHING else I can try before shelling out more money? Help, please!
Questa è una buona domanda?
Punteggio 3
2 Commenti
I'm having the same problem. I can't find a drive board info to order a new laser I also have the CUH-1215A have taken my console down to the bone but nothing in need of advice
da
Did you find a fix
PLEASE TELL ME YOU FOUND A FIX
da
Aggiungi un commento
8 Risposte
Soluzione Prescelta
Unfortunately there is likely nothing else you can do but buy a new motherboard. The one thing I will say is to look very closely at the part of the motherboard that is used for the disc drive. It is the part where the ribbon cables plug in. I've fixed several of these that have corrosion in this area and made the disc drive not work.
If that area looks nice and clean it sounds like you've checked everything else that would cause this type of problem so it may take a new motherboard to fix it.
Punteggio 3
5 Commenti:
I was wondering... What is the button battery on the motherboard for? It's located directly under the ribbon cable connector that connects to the motor for the disc drive. Is it possible that the battery is shot, and no power is getting to the motor?
da
No...that battery is the power for some of the memory. It has nothing to do with the operation of the disc drive. The power for the disc drive comes directly from the motherboard.
da
Ah, I see. I guess I'll just bite the bullet and shell out for a new motherboard then. Thanks!
da
No problem. Hopefully you find a good one for a good price.
da
Simply you can purchase a new DVD drive because models cuh-1215a and up its DVD drive is separate from mother board so you can change only DVD drive
da
Is not quite that simple you will need the old drives oem board to come over to the new Blu ray drive the board will tell you if it is a BDP 10 or BDP 20 you will have to order the corresponding part and use the existing board in your new disk drive as the Board is married to your motherboard.
You said you followed the directions exactly, so I'm guessing you swapped out the board on the optical drive, right?
Punteggio 1
2 Commenti:
Actually, with the 12xx series models, there is no daughter board married to the mother board, so there is nothing TO swap, other than the drive itself. The only board attached to the 12xx series model drives is the PCB control board, basic eject button control.
da
Brandon is right. I finally figured out why mine wouldn't accept discs same thing with the older models the apparatus holding the arms for the disc drive has a special way that it slides on to the disc drive
da
Try replacing the eject button you can get them for pretty cheap so even if it doesn't work at it won't be to much trouble.
Punteggio 0
I have unfortunately the same problem with reparing this week already. Really frustrating.
Punteggio 0
1 Commento:
One thing I can say I had that problem for about a month until I meticulously F***** with it there's a special way the disc drive goes back together particularly with the silver piece with the arms for the disc try sliding it in front side first that worked for me that's on the 1215A if that doesn't fix it then that plate could be warped possibly
da
so is this not a blown fuse on the motherboard  stopping getting to the drive
Punteggio 0
My son’s PS4 just recently started not accepting discs. Most of the games he plays now are all digital downloads but he got a new game for xmas and when he went to eject the previous game in the console,……nothing. No sound, no clicking, no lights, nothing. Restarted multiple time, had to manually eject the disc. Tried putting it back in manually but no engagement by the system at all. Once the disc was inside the system, it would not power, read, or eject.
I am now debating on whether to order a new motherboard, a new drive, an eject mechanism, or just say F’it and order an entire new PS4 and save the hassle. LOL.
I certainly don’t feel like spending 80 dollars here, and 80 bucks there only to find out I have 160 bucks of wasted parts that can’t be returned.
Any thoughts on what might be the most likely culprit?
Punteggio 0
Actually fixed my problem it was my own miniscule error.. but there's a board that only controls the ejection of the disc. Maybe the ribbon to that board has been compromised.? If not that board has everything to do with that disc not ejecting. I've only heard of this board going bad a few times before this but I'd definitely check it out. Without it operating properly the drive motors won't engage. Hope it helps!
Punteggio 0
I have ps4 and have 4 games that are digital out of the 4 ps4 will read 1 the other 3 says disc read error ive done all the steps even sadly Initialized ps4 back to factory use USB to download software from computer and into ps4 re did the settings when it turned on and yet to no avail the same 3 games wont read any ideas? Can't be the eye if it reads 1 game right?!? The other 3 still look brand new
Punteggio 0
Aggiungi la tua risposta
Brandon Martel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 11,599
