Salta al contenuto principale
The Fitbit Surge was released in 2015 and is identifiable by model number FB501BKL. This is a smartwatch that is capable of monitoring your heart rate, pace, elevation, and distance.
Why won't my battery charge?
My battery doesn't seem to be charging. I think it is plugged into the charger properly, what else could I do?
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Risposta Più Utile
My fitbit is not charging.
Punteggio 2
If your charging cable is securely plugged into your device and it is still not charging, the USB port may be faulty. Test your computer’s USB port by inserting a different device into the port and checking it if is functioning. If the port is faulty, plug your charger into a different port or a different computer.
Punteggio 1
I don't know . Someone tell me what to do .
Punteggio 1
1 Commento:
I have found an easiest way to charge fitbit charge 2.. check it out..
https://technoradars.com/how-to-charge-f...
da
Aggiungi la tua risposta
Angela Pitts sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,575
