Salta al contenuto principale
Released on June 1, 2011, with model number A665-S5170, which can be found on the bottom of the laptop.
11 Domande Visualizza tutte
Why isn't my computer retaining charge?
My computer works fine when plugged in, but when I unplug it, the battery loses charge really quickly! Is it a problem with my battery? Or is it some other issue? How can I tell?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If your computer boots when plugged in, your battery is most likely faulty, and you will need to replace it.
Try checking out our troubleshooting guide for the Toshiba Satellite A665-S5170 if you have any more questions!
Punteggio 1
It apers to be a failed or dying battery, so the fix is to replace the battery
Punteggio 0
Aggiungi la tua risposta
Chelsea Teague sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 169
