Why does my 2005 Equinox keep stalling while driving .
Why does my Equinox keep staling while driving.? I have already changed the park neutral safety switch and it does the same thing.
Questa è una buona domanda?
Ricky, have the vehicle scanned for trouble codes as a first step to help diagnose your issue as there are a lot of things that could cause this issue. Some auto parts stores will read your trouble codes for free like Nappa, Pep boys, Autozone, etc..
Maybe see if you are on or if your 2005 Equinox had the Computer changed, faulty PCM which is covered under a NHTSA Recall, as this is one of the symptoms for the recall. More info on this at link below.
Really excellent research ;-)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,542
2 Commenti
When it stalls are you at speed or sitting at a corner. does it bog and die hesitate when accelerating will it idle and if so is it a smooth idle or is it erratic . Are there any MIL on ?
da Jimfixer
Did you fixed the problem?
da Albert
