No boot after battery replacement and new trackpad
I replaced my battery and trackpad, and everything was fine (computer booted, charged up the new battery etc.). Then, I noticed that the trackpad was too hard to click, so followed instructions to make it better (turning the star-shaped screw). Upon closing the case after this, and trying to boot, the computer started to do so normally, then within a second or two, stopped and went dead.
Now, no MagSafe green light, no boot at all. After reading some posts, I disconnected the MagSafe and the new battery, and was going to wait 24 h before trying again. Also tried plugging in the MagSafe (60W) briefly after all as unplugged for ~15 min, to see if green light came on -- it didn't.
So, have I blown something inside? Should I just be patient and try again tomorrow? I am worried I shorted something...Used the IFixit Kit for all, but when screwing in the two screws for the battery may have touched something with the screwdriver...Used the plastic thingy to get the battery disconnected, so that should have been ok...
Any advice? Thanks!
Questa è una buona domanda?
4 Commenti
Have you tried booting it with the battery disconnected and the charger plugged in? Does the charger light up a very dim green, or is it showing no light at all?
da Reece
Just tried this: get a very dim green light on the charger - but no boot action at all.
da Karen Selph
Are you positive all cables and connectors are secured to the board? Pop them off, and reseat. A slightly lifted component can cause a computer to show no signs of life.
da Justin Berman
I tried popping off the connector to the battery, and any other obvious connectors to the board, but no difference.
da Karen Selph
