Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
773 Domande Visualizza tutte
Are the speakers compatible with the earlier versions (12~14mid)?
The internal Speakers in MBPr 15" 2012mid are not as good as the later versions.
Mid 15 model sound much better than 2012 version so I am trying the replace the speakers.
From the informations of the speaker parts being sold in this website, I can figure out that 2012~2014 models are exchangeable with each other. But I am not sure about the 2015 version.
Does anyone tried this before?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
As you may see on these 2 guides (for 2014 & 2015 15" MBP retina), They have the same shape, same screws & apparently the same connector. I would say yes, but I could not be 100% sure about it as this information is not provided anywhere (no part on the store, and I've not been able to find it elsewhere).
Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015
MacBook Pro 15" Retina Display Mid 2014 Speakers Replacement
Immagine MacBook Pro 15" Retina Display Mid 2014 Speakers
Guida
Difficoltà:
Moderato
1 - 3 hours
Immagine MacBook Pro 15" Retina Display Mid 2015 Altoparlante destro
Guida
Difficoltà:
Moderato
40 minutes - 2 hours
Punteggio 0
Aggiungi la tua risposta
Seungyeop Lee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 130
