Salta al contenuto principale
Repair manuals and information for the Microsoft Surface line of tablets.
128 Domande Visualizza tutte
What size torx driver is needed to remove interior torx screws
To access the components in my Surface RT tablet I used a T5 torx driver to remove the back cover. T5 is the smallest torx driver I have. What T size torx driver is needed to remove interior torx screws, such as the screws holding the headphone jack with volume control in place?
Questa è una buona domanda?
Punteggio 0
2 Commenti
My best advice is to pick up one of these guys: [prodotto collegato mancante o disabilitato: IF145-022]
Its nearly impossible to know exactly what sizes and shapes you will need in advance. Get a decent kit like that and you are set for most jobs. I have that exact one and I use it all the time. Just used it a few minutes ago actually.
da
Thanks for the tip. I ordered a set that included drivers down to T2. Another poster stated I would need the T4 driver to complete my repair. Cheers, JD
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You need a T4 and T5 screwdriver. I use these. They're pretty awesome
T5 Torx Screwdriver
T4 Torx Screwdriver
I also use this tear down, as a guide, which iFixit strictly prohibits doing. But I do it all the time anyways!
Microsoft Surface
Immagine T5 Torx Screwdriver
Prodotto
T5 Torx Screwdriver
$5.49
Immagine T4 Torx Screwdriver
Prodotto
T4 Torx Screwdriver
$5.99
Punteggio 2
1 Commento:
Thanks for the quick response iMedic. Now that I know a T4 will work, I ordered a set of drivers that will get the job done . Cheers, JD
da
Aggiungi la tua risposta
JD Shannon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,882
