Can using a heatgun on your logic board cause problems?
So my iphone had the greyed out wifi issue and after trying everything from resetting wifi networks to hairdryer/freezer nothing worked so i watched a youtube video of a guy who removed his logic board and simply heated up the wifi chip with a heat gun for 90 seconds and his wifi worked.
Long story short i tired his method and now my phone wont even turn on. I know I reassembled it all correctly because ive done it a few times before without issues.
I wrapped the whole logic board in tin foil (only exposing the wifi chip) and approx focused the heat on the chip for no longer then a minute.
Does anyone know of a few ideas of things that couldve went wrong with logic board? Is my phone toast now or is there anything i can try to bring it back to life?
Questa è una buona domanda?
2 Commenti
After all that disappointment of thinking my phone was completely damaged it wasnt. When I tried fixing it with the heat gun I had about 20% battery left so when I put it back together and tried to turn it on right away and it wouldnt power on, I assumed that it was broken but something must have happened where it drained the battery because after I put it on the charger today it booted up like normal.
I'm not saying anyone should try this method because I'm sure it could have went wrong and it didn't even fix the Wi-Fi issue so I'm still stuck with an iPhone without Wi-Fi but hey at least it works besides that!
If you do try it then just make sure you take the proper precautions not to damage your motherboard because in some cases the little bit if heat does fix the Wi-Fi issue but in my case I feel that my Wi-Fi IC is just completely dead.
da Chelsea gareau
hi the probable cause of your iphone damage after you reheat it was that you didnt know what component to apply heat, you must have applied excessive heat to NAND chip or the CPU this could be the reason as per my knowledge and experiance try to contact these guys https://www.rewatechnology.com/ they are expert in fixing iphones contact them and see if they can help you, thanks.
da anilg1972
