Salta al contenuto principale
Eighth generation of the Mazda Protege.
Rear main seal leak
I have a mazda protege 2000 I have a rear main seal leak. Where can I get a good guide to Do it myself.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Kevin, 2000 Mazda protege rear main seal leak. I f you can, I suggest you check out your local library for a repair manual on your particular model or pop into any auto parts supplier and check what manuals they have to offer. I will post a link that may help let you see what your up against when changing the rear main on protege. Check the attached link,instruction and guide, Good luck.
http://www.clubprotege.com/forum/showthr...
Punteggio 3
Aggiungi la tua risposta
Kevin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,430
