Water won't release from washer
my washer is won't let the water out after a it has rinsed or washed the clothes. Can't remember what that action is called at the moment. Basically it won't drain the water out.
Questa è una buona domanda?
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
How do you check these options if the washer is full or water??
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,309
