Apple error 4MOT/4/40000003 Main-3827
After upgrading to SDD the fan runs at a constant 3800 rpm. I installed OWC Digital Thermal and when that didn't work I installed Mac Fan Control. The readings for hardware on MFC are normal with nothing peeking over 100°F/37°C.
No matter what profile I apply in MFC the fans still spin at 3800rmp. Ran Apple Hardware Test which returned the following error:
Update (10/13/2016)
Maybe it's the battery?
Update (10/13/2016)
Dan, I noticed the "Main 3827" in the error code is the fan speed. "Main" is the only option in Fan tab of Preference window.
Update (09/28/2016)
Maybe it's the internal battery?
Questa è una buona domanda?
2 Commenti
No its not the batt sensor, unless you've got a new type of laptop ;-}
mmm... I was hoping one of the sensors were damaged. Well we need to go back to the fan as the RPM feedback is the issue as I stated the AHT error was the fan unit. But as you've replaced it with a new unit we need to focus on the logic board circuitry. Somehow it got damaged.
Sadly, you'll need to find someone with deeper skills & tools here to diagnose the logic board or you'll need to replace it.
da Dan
Hey Jose, I know this was a long time ago, but I've run into the same problem. Did you ever manage to solve the issue? Thanks!
da Greg
