Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
No video output, Cant change output mode, Can't hard reset.
Got a free PS3 that had three CDs stuffed in it and after removing them it was working fine (Stress tested, left running for about 6 hours and tried multiple game, also booted half a dozen times)
.. until I let someone borrow it and now there is no video output.
Have tried:
• Rebooting / resetting from wall, back switch etc
• Multiple monitors
• Multiple cables
• Using AV cables
• Changing video output mode (Holding down power button while AV is hooked up)(PS3 does not beep after holding power button for 5 seconds, after about 30-45 it will beep then shut off)
• Have Pulled apart a second time and checked all exposed plugs after taking top face plate off and nothing is out of place/not hooked up)
• Have cleaned contacts on HDMI port as well as possible.
I have a tech kit as I'm normally a computer / network tech so have many tools to sort this out.
Please help SOS
Questa è una buona domanda?
Punteggio 1
4 Commenti:
Are you sure your "Friend" didn't open your system up and take out a good part and replace it with a bad one?
da
It was a 14 year old girl. I'm %100 sure.
da
You can also just connect all video output options and then check them one by one till you find the one that is working.
da
Have the same problem tried the reset method by holding down red light power button for 5-10 sec NO BEEP... anyone figure this out?
da
Aggiungi un commento
1 Risposta
1. Hook up your Playstation 3 to your HDTV or TV with your cables, either HDMI or the SCART cable (Sony adapter that goes to either RCA or Component)
2. Hold the power button on your Playstation 3 until you hear a single beep and then release the power button. If you hold the power button too long, it will just power down your PS3.
3. After the beep, your Playstation 3 will reset its video outputs to the one you have plugged in and in turn will let you resetup your display options. By default, the Playstation 3 will choose composite for Display output when you use the Component SCART adapter, change this in Settings > Display Settings > Video Output Settings
Punteggio -1
1 Commento:
When I hold down power button nothing happens. No beep in 5-7 sec at all.
da
Aggiungi la tua risposta
Omri Swarbrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,738
