Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone screen lighter black
I was replacing my iphone 5 battery and when i put it back together it responds with a light black screen almost navy color.
Questa è una buona domanda?
Punteggio 0
3 Commenti:
If you took the metal plate off for the 3 screen cables, did you put the 3 phillips head screws in the correct holes when putting them back on?
If not then that is long screw damage, which would require board level repairing, not really sure how to fix it but I know it's fixable.
If the non-magnetized screw is screwed into the other two screw holes other than the top one for the metal plate it has caused damaged to the logic board then.
da
If u didn't remove the screen during battery replacement then you may have over stretched or disconnected the screen.
disconnect the battery and check the screen is connected properly before reconnecting the battery
Failing that try a new screen
da
I don't need to get involved. This question should be deleted. Look at date...can they be deleted?
da
Aggiungi un commento
1 Risposta
You damage your iPhone Lcd . Just change lcd and Solve your Problem.......
Punteggio 0
Aggiungi la tua risposta
Stephen Merritt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 102
