Salta al contenuto principale
Modello metà 2010, A1278 / processore Core Duo 2,4 o 2,66 GHz
794 Domande Visualizza tutte
Internal SSD Recommendations for MacBook Pro Mid 2010 (13")
Hi there!
I have an old HD (non-ssd) that is starting to fail on me and damage some files.
My computer as a whole is running very slow and I have been told that an SSD will make a big difference for me.
Does anyone have any recommendations? If providing my serial number helps please let me know : )
I am running running El Capitan 10.11.13 if that helps..
Thanks!
Questa è una buona domanda?
Punteggio 1
1 Commento
No need for the S/N if the system shown on the right is the correct one.
If not go to this web site: EveryMac - Lookup and plug your S/N there, then paste the systems URL here in an answer and we'll do the rest.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The first thing you'll want to do is make sure you have a full backup of your stuff on an external drive.
Next, If your drive is quite full delete some of the stuff you don't really need. You'll likely need to trim down as SSD's tend to be smaller (cheaper) than HD's. You'll want to leave 1/3 of the SSD free for a 256 GB unit and 1/4 for a 512 GB or larger. So trim away!
OK, the next step. You'll want to get a SSD that can work in a SATA II (3.0 Gb/s) system. Take the time to review the spec sheet if it doesn't state it supports SATA II you'll need to find another SSD.
You also may want to up the RAM if you have a 4 GB model. I would go to 8 GB (light user) or 12 GB.
Now go to the App store and download the OS installer if you don't have it in your Apps folder already. I would recommend making a copy then create a bootable USB thumb drive. First reformat the thumb drive using Disk Utility with GUID partition mapping and format the partition Mac OS Extended (Journaled) the launching the copy of the installer to install the OS onto the thumb drive. This serves two functions one to get you comfortable on what you'll do with your SSD when you install it and create a boot drive just in case!
Follow this IFIXIT guide to take your old drive out and put in the new SSD in, as well as replace the drives SATA cable as well as thins series has a known issue with them: MacBook Pro 13" Unibody Mid 2010 Hard Drive Cable Replacement. Here's the better cable: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104.
Once the new SATA cable & drive are installed you'll need to boot up under either your old drive or the thumb drive we created to install a fresh copy of OS.
You'll still want to hook up your old drive to your system so you can leverage the Migration assistant to bring everything over. You'll want a SATA to USB adapter cable like this one: Startech 2.5" SATA to USB adapter.
Don't worry, If you have any problems were here to help!
Immagine MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Prodotto
$34.99
Punteggio 3
6 Commenti:
Thanks! This is very helpful. I think I am just going to have someone at a local store install the new HD for me. I have tried this before and messed it up. Not worth it.
Regarding the HD, do you have any recommendations as to which one I should get? Maybe a specific brand?
Thanks!
da
If you're going for a HD then I would go with a Seagate SSHD w/32 GB of NAND flash. If you have a few more pennies I would go with the Samsung 850 EVO SSD.
da
This is indeed very helpful for mid 2010 macbook pro
What about this one for SSD modification ? https://www.amazon.com/Crucial-MX500-500...
And ram upgrade with this one ? https://www.amazon.com/OWC-204-pin-Upgra...
da
@alican43 - The Crucial SSD is a fixed SATA III (6.0 Gb/s) SSD it is not able to work within a SATA II (3.0 Gb/s) system. Review the spec sheet for the drive it must state it clearly. As an example Samsung 860 EVO states it on the Interface line: "SATA 6 Gbps Interface, compatible with SATA 3 Gbps & 1.5 Gbps interfaces"
da
Which brand or model RAM do you suggest to go with Samsung 860 EVO on mid 2010 macbook pro 13inch ?
da
Mostra 1 altro commento
Aggiungi la tua risposta
Zachary Grossman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,949
