Salta al contenuto principale
The Samsung Galaxy Tab 4 8.0 from Verizon (SM-T337V), also known as the Samsung SM-T335, was launched on April 1, 2014. The 8-inch tablet is powered by a 1.2 GHz quad-core processor, has a multi window functionality, and a 3 megapixel camera.
20 Domande Visualizza tutte
Are lcd's compatible between versions of galaxy tab 4 8.0?
Hi i need to know if the lcd's for other editions of the galaxy tab 4 8.0 are compatible with the lte version? I need to replace for a customer and want to provide cheapest possible service and the other models have cheaper lcd replacement options. Thanks in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
There are for sure different parts for 4G/wifi versions, which is usually a good hint that something is different. Taking a look at them, it appears as though the 4G antenna may be sandwiched in the display assembly.
I would for sure use the correct one.
Punteggio 1
Fraser, if the lcd's are different part #'s, then you can bet there are differences, you would be taking risk in ordering anything but the correct part # for replacement.
Punteggio 1
Aggiungi la tua risposta
Fraser Dalgleish sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 90
