wont turn on after diy repair
after replacing screen myself Iphone speaker was not working so I was going to check the #3 connection and forgot to turn off the iphone before taking apart. checked all connections multiple times, have waited 5 mins for reboot several times. Did I fry the iphone by not turning it off before taking apart? IF so can I fix it?
Questa è una buona domanda?
4 Commenti
I also have the same problem. I repaired my iPhone's cracked screen and after reconnecting everything it wont seem to turn on. I thought I might have broken the LCD but even if it were broken it would atleast glitch or something
da pillsburyboi
hey, i did tear down too of the top glass part on my iphone 3g and once i put everything back together, i couldn't turn the iphone on (or it seemed that it was off). But once I plugged in to charge it, the screen started working. What could be the reason? Thanks..
da vik
this is a very common question, and i have yet to find a detailed answer on this website. Everyone seems to ignore it, and it's torturous because i have the same problem. Repaired everything fine. Connectors are in place...phone's display will not work. Itunes charges the phone, and I can toggle the vibrate/ringer switch to make the phone vibrate...but that's it. PLEASE HELP! Many people have asked as i've searched for this for hours upon hours.
da Taylor Jones
is the phone actually charging? if not, then there seems to be a connection problem. Try and see if the battery is actually connected. Tell me what happens after you do that. Let me help you
da Trey Dollarz
