Salta al contenuto principale
Repair and troubleshooting information for the Suzuki FA50 Moped.
20 Domande Visualizza tutte
My moped dies when I am not constantly turning the throttle.
I am new to working on my moped so any help would be appreciated, i also have more questions but this one is my main concern.
So i can start the moped no problem its a little rusty but in order to keep it running i have to have the throttle turned a bit, is that normal?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sounds like you might need to adjust the idle.
Try adjusting these two screws and see if you can get it to idle without hitting the throttle.
Punteggio 3
Risposta Più Utile
Chase as Randy C. suggested try the idle mixture screws first, if that does not do the trick, the carburetor will probably have to come apart and be clean/rebuild.
Punteggio 4
1 Commento:
Also check that the gasket is sealing(no vacuum leak)base of carb. to intake on cylinder,
da
Aggiungi la tua risposta
chase sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 7,228
