Salta al contenuto principale
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Canister Purge Valve How To Replace
I have the new part I just don't know how to take the old one off without breaking anything. 2003 Cavalier 2.2L
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
Jeremy,
I found this YouTube video that makes it look like a breeze.
Best of luck!
Punteggio 1
6 Commenti:
I have a Cavalier and the valve is in a completely different spot on my car it's next to the motor right under the hood
da
Jeremy,
Check out the video though for the method. Is the cavalier valve alot different than the impalas? Or is it that it's in a really tough to get to spot?
It seems like the process would be very similar.
Best of luck
da
in my 2002 Cavalier 2.2L (vin-4), the purge valve is in-between (behind) the engine (mid point) and in front of the firewall (mid point or toward the passenger side) and under the fuel rails of the engine (under and to the right of the computer module) which is under the air intake cover, anyone have or knows how to get to it?
da
An Impala is a v6/v8 rear wheel drive full size sedan. A Cavalier is a sub compact coupe or sedan. So its like comparing the HMS Titanic to the SS Minnow.
da
Joe did you ever figure it out? I have same issue and it looks like you have to take apart half the motor to get it out
da
Mostra 1 altro commento
All answers are insane. Do not listen to any of them
Punteggio 0
Aggiungi la tua risposta
Jeremy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 91
Tutti i Tempi: 17,671
