Salta al contenuto principale
Il primo modello di iPhone (A1203) con 4, 8 o 16 GB di memoria interna e retro in alluminio. La riparazione potrebbe richiedere alcune saldature e una buona dose di forzature sui componenti.
222 Domande Visualizza tutte
ear speaker not working
can't hear anything from the ear speaker. what should i do?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hello, Had the same problem. I solved it myself it's pretty easy. The headphone port on top of the phone collected lint and fibers from my clothing like your jeans pocket. The lint got in between the contacts of the headphone terminals so it was open circuit so the sound was cut off. Just remove back cover unscrew headphone port clean inside with tooth pic using the pic to remove as much lint and fibers as possible the spray some electronic contact cleaner into hole flooding it so it pours out. Use plastic friendly cleaner as the plastic housing would melt, the can must say plastic safe. Hopes this helps. CHEERS /Randy from Trinidad
Punteggio 3
2 Commenti:
hi randy, thanks a lot. i'll try it.
da
Thanx. Got the same problem and I'm gonna try your solution. great.
da
Aggiungi la tua risposta
manny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,438
