Salta al contenuto principale
The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
78 Domande Visualizza tutte
My microphone is not working
my moto g2 pdone mic not working and i dont no where its location in fone kidly help me asap .
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Try checking the Moto G teardown to identify the component you're looking for:
Motorola Moto G 2nd Generation Teardown
Punteggio 1
Can't hear anything when I am on the phone or watching videos.
Pls help me quickly.
Punteggio 0
Definitely use to tear down above to disassemble your device and look for where the mic is to see if there is any clogs of dirt or possible moisture damage. If you see any white crustiness any where on the board, go ahead and grab a tooth brush or something similar to it, and use a little bit rubbing alcohol to clean up any areas that may have been exposed to any liquid damage. If that still doesnt work you will need to replace the mic which is soldered to the board and is not an easy job if you have never done micro soldering before.
Hoped that helped, have a good day.
Punteggio 0
Aggiungi la tua risposta
amritrajbhardwaj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,986
