It can not recharge
you can see the amount of charge, but with the connector does not happen charging
thank you
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 62
there could be several reasons to why it doesn't charge but the most common are bad batteries, water damage, broken charging port. all three of these are recommended techs only to fix so i'd take it to my local repair agent and get them to have a look. good luck
da Hortman
Peppe, what do you mean by this "with the connector does not happen charging"?
da oldturkey03
The USB port is ok
He did not take water
da Peppe
the battery if the load with bench power supply accepts the charge
the problem is that you do not see the charging status
da Peppe
