Salta al contenuto principale
Released in June 2013, the Galaxy Mega is a 6.3" smartphone featuring a 720P display, dual-core processor, and an 8 MP camera.
54 Domande Visualizza tutte
Why does my phone say network or sim card error
Hi, I recently just got new phone and I went to get it activated and when I went to call on my phone it would just ring . So I decided to go to my setting and go to network to see what the problem was but it wouldn't let me cause it said network or sim error but I had my sim card in it .... what should I do ???
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi, Have you inserted the SIM card correctly? If so, have you tried your SIM in another network compatible mobile phone and see if it works? Have you tried another known working network compatible SIM card in your phone and see if it works?
da
Aggiungi un commento
2 Risposte
Reposted from Comments for visibility.
"Hi, Have you inserted the SIM card correctly? If so, have you tried your SIM in another network compatible mobile phone and see if it works? Have you tried another known working network compatible SIM card in your phone and see if it works?"
My Thoughts:
Your phone may be network locked perso locked or banned from the carrier your attempting to use. Call your carrier to check your IMEI. Also, You may want to try gently wiping down the sim card with alcohol. (Do not put it into the phone until it is dry. You have been warned.)
Punteggio 0
My samsung Network or sim
Punteggio 0
Aggiungi la tua risposta
Jazzy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,444
