Salta al contenuto principale
A sanitary disposal device for human waste. No plumber necessary! Fixing a toilet is more straightforward than many people think.
25 Domande Visualizza tutte
Consistent dripping sound coming from tank
There is a consistent dripping sound coming from the tank of my toilet. What could it be?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Over time the flapper - which is soft and supple new - becomes dry and hard. Replacing the flapper will normally fix a dripping issue, and it's about a 5 buck repair.
Punteggio 3
Risposta Più Utile
Flap which stops water to come in side has been wastage.It would be change.
Punteggio 6
1 Commento:
Really a score of 8 on this answer! Really amazing and total BS. Having your buddies vote a poor answer up like this risks getting you banned from the site.
@kaykay
da
Here's the guide on replacing the flapper: Toilet Flapper Replacement
Punteggio 5
Try putting a new tank kit in it?
Punteggio 0
1 Commento:
It may be time to replace the whole kit soon anyway. As there is no visible water leaking from the tank and no overflows ever, I just wonder what it might be.
da
It' cause of a bad flapper, it can't hold the in the tank and the water is dripping from the tank. You should replace the toilet flapper asap.
Punteggio 0
Aggiungi la tua risposta
Max Fishman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 17,524
