Salta al contenuto principale
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
It's not working and recovery adb problem
Hi *
I unlocked my Nexus 5 n root it n install twrp recovery n install cyanogen mod 13 with gapps
Then I opened super su it says update the software I click on update cwm/twrp
After that it shows only google screen I have done hard factory reset.
Nothing is working.
When ever I turn on my phone only text google appeared with an unlock image
I can't apply adb update cm recovery
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If you are fine with losing the data, you can reflash the os (https://www.google.com/url?sa=t&source=w...) over the bootloader interface. That would remove CyanogenMod and wipe your data, but your phone should run properly on stock Android again. since your bootloader is unlocked, you could also flash just a new custom recovery, for example twrp, and use it to flash a zip containing CyanogenMod, if you have one have one on your phone. The procedure is basically the same, but instead of downloading the system image, you download the custom recovery and run the command "fastboot flash recovery <file path for custom recovery>" to just flash the recovery.
Punteggio 1
Aggiungi la tua risposta
Osman Shaik sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 226
