Salta al contenuto principale
Crashes on start up
If my laptop goes into standby/sleep mode, I can use it and turn it off but the next time I turn on my laptop it will crash on start up and will say to search critical_process_died. I have searched that and cant find a solution. It crashes every time after it has been on standby/sleep mode on the previous use. This has been happening since I got the laptop a year ago.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi,
What happens after the crash, how do you restart it successfully?
Just a thought. If it starts normally after you shutdown after the crash it seems that the "shutdown process" after it has been in standby/sleep might be a factor.
What OS is installed?
da
Aggiungi un commento
1 Risposta
Typically on a prebuilt computer (laptop or desktop) this can signify one of two things; 1. A faulty display driver, which could be solved by uninstalling your current graphics driver and redownloading the driver from the manufacturer website, or 2. A faulty windows installation. I would recommend attempting to perform a "refresh" (for Windows 8/8.1/10) and see if that fixes the issue. There are several other possible scenarios, but these two would be the most common, in my opinion.
EDIT 1: One other possible fix if the other two fail would be to see if there is a BIOS update.
Punteggio 0
Aggiungi la tua risposta
Ailish O Connor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 306
