Salta al contenuto principale
Quinta generazione dello smartphone android al top di gamma Samsung, rilascaito l'11 aprile 2014. I miglioramenti rispetto alla serie successiva comprendono lo scanner impronte digitali, la fotocamera aggiornata, lo schermo più grande e la resistenza all'acqua. Disponibile in quattro colori differenti: nero, blu, bianco e oro.
577 Domande Visualizza tutte
My dad's S5 screen displays only a white noise.
Since today my dad's Galaxy S5 started to display only a white noise like seen here.
I tried everything from pressing on different parts of the back, draining it's battery and reinserting it several times, but nothing worked and I can't even go into recovery mode because I can't see anything but the noise.. My dad thinks it's a virus but I have installed an antivirus on his phone and I doubt it could've caught a virus.
Please help me, the last thing we want to do is buy a new phone, but the s5 doesn't even have a scratch and it would've been a bummer to throw it away or pay the price of a second hand one just to repair it, thank you very much in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
This sounds more like hardware than software.
You will need to open it and check and clean all LCD screen connectors in the motherboard and screen.
Advisedly to try as well with another LCD screen to discard any damage in current one.
In any case open it and inspect with a magnifier.
Good luck and good repair.
JM - Montreal, QC
Punteggio 1
Just for any one finding this post.. In the cases I have experienced this is a hardware fault.. I've had it a few times with Galaxy S5's and replacing the LCD has fixed the problem every time..
Punteggio 0
2 Commenti:
Correction to above post, I'm currently scratching my head over a phone that had the problem and I fitted a new LCD, problem solved.. two weeks later, same issue.. I'm currently downloading new firmware, which is a shot in the dark.. then maybe look at the board.. maybe slap it with a wet sardine.. :(
da
I currently have the same problem can't even recovery boot anymore, just white screen. Tried a new LCD same results.
da
Aggiungi la tua risposta
mihailapatrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,404
