Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus.
4806 Domande Visualizza tutte
Touch wont work after dropped in watter
hello everybody! i have iphone 6.. before 3-4 days it dropped in water (the top of the iphone ) i put it oute quickly i make it dry and after one day iphone open .. but touch wont work.. also i see down on screen some grids you can see the photo i send u
now.. i already order new screen i will change it tomorrow cause i m still on holidays.. but i want ask.. the problem is with lcd & digitizer or its on board? maybe have some water hidden and i must clean better? or if i change the screen it will work fine? thanks!
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Commenti:
thanks for your reply.. i will replace it tomorrow then i already buy one high quality lcd & digitizer A+++ i hope it will be good quality .. i will post the resaults ! thanks again
da
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
2 Risposte
Soluzione Prescelta
Use this teardown to start your water damage repair.
Then use the Water Damage Guide for how to clean up the phone. Be very careful. The guide really is important because you don't want further corrosion in your phone.
Once everything is taken care of, you will definitely need to replace your screen. Follow this guide for the screen replacement, then another for the home button, and lastly, one for your front camera assembly. The home button, camera, and LCD shield will need to be transferred since they do not come with the new screen. Definitely be careful with the home button as you will lose touch ID if you ever have to replace it.
Immagine iPhone 6 LCD and Digitizer
Prodotto
$69,99
Immagine iPhone 6
Guida
Smontaggio iPhone 6
Difficoltà:
Moderato
Immagine iPhone 6 Schermo
Guida
Sostituzione schermo iPhone 6
Difficoltà:
Moderato
20 minutes - 1 hour
Immagine iPhone 6 Cavo della fotocamera anteriore e del sensore
Guida
Sostituzione del cavo della fotocamera anteriore e del sensore nell'iPhone 6
Difficoltà:
Moderato
30 minutes - 1 hour
Immagine iPhone 6 Pulsante home
Guida
Sostituzione pulsante home iPhone 6
Difficoltà:
Moderato
30 minutes - 1 hour
Punteggio 2
Commenti:
thanks for your informaton! i will follow all guides
da
Good luck and keep us posted!
da
i follow the steps and i replace the screen .. iPhone open normal but touch still wont work. Maybe have damage on board? should i send it to someone who know fix boards?
da
Do you have a grey bar on the top of the screen?
da
after i change screen i dont have bar only the touch dont work
da
Your screen has water damage and needs to be replaced.
Punteggio 0
Aggiungi la tua risposta
emted16 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 109
