Salta al contenuto principale
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
20 Domande Visualizza tutte
'07'Corolla LE Spontaneous or constant horn
My 2007 Coroll LE horn often honks when the steering wheel is turned. Sometimes the horn honks when car is parked with engine off. Removed fuse as temp control option. Dealer wants $130/hr just to diagnose problem.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
i guess it only can be a damaged Cable, like it has a crack in it and the cracked part connects to some Metal Part on the car and so a short circuit happens. So at first you should have a look at the Cables going to the Horn, and on the Connectors. (Sorry for the Bad English)
Punteggio 0
Aggiungi la tua risposta
Lewis Fairchild sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 153
