Why can't I use my phone while it's charging?
I lost my note 5 and it ended up sitting outside in the rain. Initially it would not charge or run at all so I turned on my old s4 and let my note 5 dry out for 2 weeks with the Sim card removed for the last week.
My phone now works,
- Camera is clear
- All speakers work perfect
- * Makes/Receives calls
- * Speakerphone and Music play clear
- Screen has no damage
- All buttons work
- Holds a charge
- Doesn't get hot or overheat
- Charges (only while powered off)
- Works flawlessly when it is on and NOT plugged in.
The only problem is that if it's ON and you plug the charger in it will start rebooting, and as soon as it reboots and goes to turn on it will reboot again, so I have to charge my phone while it is powered off, which is a problem when it's my alarm for work. When it is on and not plugged in it doesn't freeze, reboot, or have any other working/running issues. I have also already tried doing a factory reset to see if it would help and it didn't. Could the battery be damaged, or possibly something else?
Questa è una buona domanda?
