Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
5065 Domande Visualizza tutte
Domanda Chiusa
How can I Recover Lost Contacts from iPhone 6?
Is there any method to recover Deleted Contacts from iPhone 6?
Questa è una buona domanda?
Punteggio 0
Commenti:
Atually, there are more and more iPhone data recovery tool avaliable. So, you can google a good one to recover your lost contacts or other iPhone data.
iRefone is one of the best iPhone data recovery softawre. I'm now using it. Have a trial please.
da
Aggiungi un commento
Kit per Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Risposte
Risposta Più Utile
If you want to recover lost contacts from iPhone 6 then it is only possible if have the backup on iTune or iCloud.
iTunes
If you have your backup on iTunes then install iTunes on your machine.
Then connect your device to that machine, give iTunes some time to recognize your phone.
Then click File > Devices > Back up (if you don't see a File menu, hold down the Control and B keys).
Your backup should be ready to use now.
For restoring backup.
Start your device and connect it to your machine where you had taken backup using iTunes earlier. While setting up new iPhone, select ‘restore backup' instead of setting up a new device. It will take some time for iTunes to restore data and you are good to go.
Punteggio 1
https://drfone.wondershare.com/ Has proven me well over the past year whenever I delete something for no reason.
Hope I helped.
Tyler Hoban
tyler.hoban@gmail.com
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 180
