Salta al contenuto principale
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
Won't turn on with/without plugged to AC charger
Hi, my speaker does not turn on, when it is plugged to the AC I'm able to see the battery light but it won't turn on with or without be plugged to the power adapter.
I already updated its firmware but it did not work.
Please help !!
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta Più Utile
I just had this problem. Did some searching and came across this: update.bose.com/soundlinkcolor to update my SoundLink's software. If that doesn't work (or if your unit's software is up to date), do the following:
1. Plug SoundLink's in to wall charger
2. Hold down the play/pause button for 15 seconds.
3. Then, BEFORE releasing the play/pause button, unplug the charge cord from the unit.
4. Release the play/pause button.
5. Plug the unit back into the wall charger.
6. Press the power button, and your unit should power on.
Side note: Steps 1-4 above put the unit in "ship mode" and steps 5-6 take it to 'normal mode'.
Punteggio 6
Not working
It is not working when I plugged in to my charger
Punteggio 0
Aggiungi la tua risposta
arturorv00 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 9,125
