Salta al contenuto principale
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 Domande Visualizza tutte
iMac won't boot - freeze at Apple logo - graphic card dead?
iMac EMC No.: 2134
Model No.: A1225
Hey guys,
since a few days my iMac won't boot anymore. After pressing the on button it is showing the apple logo and then the loading circle.
I am able to access the screen where I can select the different boot options or the bootable stick I have on via usb. But it does not matter which option I choose, it starts to load, showing the loading circle or a process bar (when trying to boot from UsB) but it freezes after a few minutes.
I also tried to access the BIOS like screen where it shows the booting process, but I wasn't able to read the problem from it.
I then brought the iMac to a local store to check it - they said that the graphic card would be dead and there were no replacement parts available. But I still wonder if this is right because the graphic card seems to be alright as the iMac is showing perfect screen and colours when accessing the hard-dive-choosing screen.
Do you have any advice how I can find out what's wrong with my iMac?
Thank you already in advance.
Best
Marvin
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
If you are getting a screen the GPU is probably OK (although that is the most common issue on this machine). This sounds more like a hard drive issue.
#1 Try starting up in Safe Mode by holding down the Shift key on start up.
  1. 2 Try holding down the Command & R keys and select the repair partition on start up if you have one.
# 3 Let me know your results.
Punteggio 1
Hello mayer,
Thank you for your answer. I tried to boot in safe mode but after about 1/3 of the big status bar it changes to the round loading circle and gets stuck after about 1 minute. You can see on screenshot 1.
I also tried the CMD + R command, but it would not load anything but the loading circle with the same result as in screenshot 1.
One thing that works is to load the screen where I can select any harddrive via the ALT key on startup. But whatever I choose (Recover hard drive, Bootable USB Drive) it fails to load it. Gets stuck after a few minutes at the status bar at about 3/4.
Does this screen tell us that the graphic card is okay?
Any ideas left on what the problem could be? Or how I could find out?
Thanks for you help!
Best
Punteggio 0
1 Commento:
The screen and therefor the GPU appearing to be working just fine. I would next try that fourth icon in Safe Mode. What appears to be a mavericks system. That failing do the system installation. I do not see a repair partition, so I suspect an incomplete install or an older system on your main drive from before repair partitions were installed. This can also happen when you do a cloned installation. Do you have a backup hard drive with a system on it or another Mac you can use Target Mode with?
Also, please unaccept my answer until your problem is solved.
da
Aggiungi la tua risposta
Marvin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,406
