My Samsung TV ue46d6500vsxzg is Black and was before Hot
Hello
First ive done nothing but they were some red mysterious lines on first half of the screen.
The same lines like in these video at the end https://www.youtube.com/watch?v=j7vl7-vZ...
When i turned on the tv. The lines could only a bit be seen but were not tragical at the beginning but after a while these lines were thicker but not so big that they disturbs you can watch tv further on with no problems.
After a week not only the lines were there a circle on the rand side was there. A semicircle
Ive drawed it here. http://fs5.directupload.net/images/16063...
Ive touched light the side of the tv and detect that the position were the circle ist was extremly hot. So hot that you can burn your finger. The other rand sides were normal temp.
Ok. Than ive opened the lcd tv and tried the same thing like on the youtube video that ive postet before. It did not work but the lcd went black.
I dont know what happened. But ive done exactly the same as the Person in the video. Maybe shortcircuit? The Power gone off and when i try to power the tv on again, nothing happened. All silent.
Ive took out the mainboard the t-com panel and the power panel to see if something is burned or capacitor has been damaged. Ive seen no black burned traces.
Ive builed everything in again and the power was there. Ive a light behind the tv in a screw hole when the power cable is in. If i turn the tv on Something in the font is blinking but ive no picture all is black. If i use a flashlight. i see nothing. Ive i try to change source withe the source button something blinks.
My Problem is, i dont know whats defect. The Power Panel, the Mainboard or the tcom. When i plug out the tcom the tv makes the same as when the tcom is pluged in.
Really hope someone can help.
More Pictures:
Power Panel:
TCom:
Mainboard:
TV Back:
116 cm (46 Zoll)
Ultra Clear Panel
LCD
Backlight Technologie
LED-Hintergrundbeleuchtung
Clear Motion Rate/Bildwiederholungsrate
400 Hz (CMR)
Mega Contrast
Full HD 1920 x 1080 Pixel
3D HyperReal Engine
Wide Color Enhancer Plus
Update (07/01/2016)
Thank you very much for your answer!
The Problem is that this time when i turn on the tv it stays black. When its black it seems that no heat at this red circle marked position accrued. Without colour its all cold.
Turning on the Tv makes normal noises. 1 click. when i turn him on and 1 click when 1 turn off. Seems all like before but without any picture.
//Added another picture
Ive checked all panels (front and backside) with a magnifier but maybe ive overlooked something. I could make sharp pictures.
Update (07/02/2016)
[img]http://fs5.directupload.net/images/16070...[/img]
I've opened up the panel and i looked where the hot spot was.
Is thats the reason that i don't have picture anymore?
How many does a new Panel cost?
Where can i get it?
Renumerates it actually?
Questa è una buona domanda?
2 Commenti
This "When its black it seems that no heat at this red circle marked position accrued. Without colour its all cold." sounds like your LCD panel is shortening out, not the boards.
da oldturkey03
Where can i get it?
da Hans
